for it to get up to full temp where the gauge is at half way point, about 20 minutes, for oil temp to be ok its about 5
I find that it's the other way round. Water temp takes about 5 minutes, oil temp takes quite a bit longer, normally 10 minutes or so.
work days i leave for work at 1pm so 12.50 i start her up and leave to warm up. then set off
I miss my clio 16v for this I used to love the oil temp dial !
Out of curiosity does anyone know if this is this bad for the engine?
I have done this before on cold mornings to defrost however I have also heard that by leaving it on idle the rpm is not sufficient to aid oil distribution...
I got a non sport 1.2 8V if I drive to the girlfriends (about 7 miles away @ 30mph) my temp gauge isnt even a quarter way. Think I may have an issue? lol thats about 20 mins of driving... How ever if I drive for about 30 - 40 mins thats when it gets up to temp
Nick
Bugger... Am I currently in danger of anything bad happening with the car as it is? Should I change is as soon as?
Nick
I wait for the oil temp gauge to reach normal (I forget where that is just now).
Warm water? Thats for poor idiots
Well you know what you'll be doing when i come to see ya then...probably needs a thermostat, like most 172/182s
Actually, warm water is more sensible. Less rapid temprature change, so less chance of glass cracking if there are any chips (I believe that this is correct, I may be talking out if my arse)
Yup that's probably correct. I'll stick with the heated windscreen though.
Ah right, how very bourgeoisYup that's probably correct. I'll stick with the heated windscreen though.
