Warning lights coming on an off - SERV / Airbag
  Clio 182
So as title
The SERV and airbag light stay on then after a restart they go out.
The car had a full service today also so all good there. This has been happening since i got it, Someone else picked the car up for me so never mentioned it to the garage
I can take it back no issue - im just curious
TIA
  172 cup turbo
Could be the connection under either the driver or passenger seat. Try unplugging then plugging in again. If not cut plug out n reconnect wires
Could also be a break in your steering wheel squib as I had recently
Best thing to do mate it plug it into a computer to find what is causing the fault before replacing things though
  Clio 182
Ta for the replies
It happens when i give it the beans and only then so sounds now i think about it, could be a loose connection
Drove it like me grandad from the shops a little earlier an its fine. Booted it and there it is, gone off again now lol
  Many.
Get a garage to plug it in, most likely seat wiring moving as you boot it and just loosing connection slightly, very common on Clio's and many other cars for that matter.
