Washer jets
  Clio 172mk2
they`y only work when head lights are on , then i think its every third pull when u wash windscreen
  Seat Ibiza
Dodgy motor? Was it lacking in pressure?
Is this true, if the lights are on its every third wash? I have never noticed...?
  Seat Ibiza
Dry connection, poor connection to the fuse, bad switch? Does the switch feel as it has the right resistance?
Knuckles
ClioSport Admin
While were on the subject... What would be needed to fit fully working washer jets to models without them, I've got hold of a 1*2 bumper that has the jets and pipes... Would it be easy to do or not worth it? Just a thought
Most people dissconnect the xenon washers because they leak and leave a water mark trail all down the side of the car or just leak on there own emptying your water tank!
Id leave them dissconnected mate, if you have xenons just give them a wipe over if they get really dirty, if you have normal lights you wouldnt need or want em :)
  Seat Ibiza
I believe it's just a different pump mate, and a different washer bottle, which I can't find second hand anywhere.
But like Guysy says, leave them there, but don't connect them, they don't really do much! And they make a mess...!
  182 Ly ff.
Mines leaking and bought a one way valve from halfrauds. Not sure where I should be fitting it though? Anybody know where too fit it? Around the wheel arch iirc?
