water pump leaking. Anyone Help?
clio 1.8 16v mk1
water pumb is leaking from a little hose just under the the pulley.
it is not a screw hole or anything else, why is this? some sort of seal?
and how much trouble is it to change the pump?
thankyou
having never done this im not posative but i think itll be a big job
water pump is usually changed when doing cam belt so u may have to remove cambelt or even engine to replace pump
good luck m8
belts off, alternator removed, pulley removed,pump bolts removed all except 2 which are impossible to get off, ive just spent half an hour trying to remove one.
Anyone got any advice?
