My water temperature gauge hardly ever shows normal temperature usually it shows around a third then occasionally almost up to normal then drops. The mpg also doesn't seem to show much more than 31-34 mpg It's a 172 phase 2 it had been off the road for a while, it's had new spark plugs, stainless steel exhaust, and v6 air box, the water levels seem fine, the exhaust is black and could mean it's burning too much fuel
Are the temp gauges reliable on these cars, or is it more likely the sensor, thermostat and what's the best way to check. Otherwise it's running ok
