Website DNS issues
  172 Cup
Straight on -
LoonyAsylum.net Discussion Forum
Can you get on - 69.61.9.50 ??
  172 Cup
Probably not a DNS problem then. More likely a routing issue, see if it works in 48 hours time.
  172 Cup
Well it's definately not the site (checked here and from docklands via vnc) and if you can't connect direct to the IP it's not DNS. That leaves routing as the likely candidate.
  172 Cup
Telephone > ISP > "Hello I have the following problem...." > Probably receive some bullshit > Resign yourself to accessing it from work only
  172 Cup
So did my little toe until i broke it.
Things work and then they break. You know yourself the site works (from work) so it's down to your ISP/connection/routing.
The only other option is they have blacklisted you from the site.
  172 Cup
lol
You'd have to ask them that matey.
Actually one more thing to try -
Go to Start > Run > Type "cmd" and press enter.
Type "tracert www.loonyasylum.net" and press enter.
Copy and paste any results you get*
* In command window you need to right click and use the "mark" option to copy/paste.
"Should" look like this -
Tracing route to loonyasylum.net [69.61.9.50]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms home.gateway [192.168.1.254]
2 28 ms 27 ms 29 ms cr0.cmwl.uk.easynet.net [82.108.10.99]
3 21 ms 22 ms 22 ms 82.111.100.65
4 22 ms 22 ms 21 ms 82.110.134.1
5 28 ms 28 ms 27 ms ge0-2-0-0.br0.thlon.uk.easynet.net [195.172.211.
138]
6 28 ms 27 ms 29 ms ge0-2-0-0.er2.thlon.uk.easynet.net [217.205.205.
118]
7 29 ms 28 ms 29 ms cr02.ldn01.pccwbtn.net [195.66.224.167]
8 145 ms 144 ms 144 ms globalcompass.ge2-1.br01.atl01.pccwbtn.net [63.2
16.31.134]
9 146 ms 145 ms 146 ms ge-1-atl1-cust1.globalcompass.com [66.154.95.221
10 145 ms 145 ms 146 ms denver.servershost.net [69.61.9.50]
Trace complete.
