Hello guys,
A week ago i started to hear a noise during the drive. It will start after the 10 min driving and comes from the front part of the car. At first i thought it is wheel bearing but the sound is constant, it will not change according to speed. This sound will disappear if i push a brake pedal.
Sometimes i have noticed that if i turn the wheels, then it seems also disappear, which should tell, that wheel bearing needs replacement.
If the wheel bearing is faulty, then the noise should appear immidiately ? Then the noise shoud be louder according to speed increase ? The brake event should not effect the noise ?
At idle speed engine is running smoothly, so it cannot be any engine fault also.
Could someone suggest, what could be wrong or is these symptoms similar to wheel bearing fault ?
Thank You in advance !
Madis
Madis
