Megane RS DIY turbo conversion? thats what i'm doing
Wouldn't you be better getting the further work done before the remap?
no, i'm using a 172 engine and box as a base to start from
Can you do me an uprated gear box!!! pleeaaaasssee!!!!![]()
right i currently have a viper, matched inlets, 182 manifold, decat, magnex exhaust, and a remap in a few weeks.
what is the next logical step in tuning the engine? i was thinking cams and headwork? can anyone shed some light and some rough prices, thank you
buy a 2nd hand Megane RS engine cheap, pull your 172 engine out
strip both engines down and swap pistons into the 172 block, whack the MRS head onto the 172 block stick it in car, remap bo selecta
its not the gears that are weak in the JC5, so shot peening would be a bit pointless
its the bearings and the casing thats the weak points
is it worth having headwork done at the same time?its around £1700 odd inc map and new cambelt etc
