G Gez08 Car clio 172 cup May 3, 2009 #1 Hi when buying new wheels what offset is best or what offsets are available for my clio 172 cup? Thanks
F Fred@BTM Car Lionel Richie May 3, 2009 #2 approx the same at you have now, ET37 to ET45 is the range that will fit stock is ET38.5, so the higher the number the narrower you'll make your track width = stupid
G Gez08 Car clio 172 cup May 3, 2009 #3 Thanks thats helped alot, also what is the stud pattern? is it 100 or 98?
F Fred@BTM Car Lionel Richie May 3, 2009 #4 PCD (aka stud pattern) is 4 x 100 centre bore for clios is 60.1mm
