What size fuse ?
  Skoda Fabia vRS
the wiring kit ive got for my amp comes with a ANL 150A fuse, which i think is far too big
what size fuse do i need for about 600W RMS ?
the amp has 1 x 80A mega blade fuse
i was thinking the same on the power cable, or less if they do em
these are about the cheapest i can find
http://cgi.ebay.co.uk/A-PAIR-of-Car-Audio-Amp-Flat-Fuse-100A-ANL-High-Current_W0QQitemZ5858649247QQcategoryZ14932QQrdZ1QQcmdZViewItem
but they are 100A, also do they blow very easily ?......as ive known the normal gold ones to blow just changing them or connecting the power cable to the battery
  Polo + Micra
anl fuses are pretty good fuses
the fuse on the power cable is just for protecting the fuse so anything upto it's max is fine
  Skoda Fabia vRS
right, ive been reading talk audio, and it seems the fuse on the power cable is only there to blow before the cable gets hot and causes a fire, the fuses on the amps protect the amps
if i can get some 80's ill put those in
