What size wheel trims
Hi, I hope someone out there can help me. My daughter has an "H" reg Renault Clio, and that is all I know about it! (Well, it is white, but that doesnt help much!!!) She needs some new wheel trims and I want to get some as a Christmas present for her, but I cant find out what size to get. I have even tried lurking round the car park at the hospital where I work (at the risk of getting arrested!) but cant find a car the same to measure. I dont want to ask her cos then it wouldnt be a surprise. Can anyone tell me what size trims I need to get?
Many thanks
Chris
probably 13" but have to check on the tyre, the size will be printed on the sidewall, there will be three numbers the 1st one will be 3 digits long (eg 175) this is the width, the second will be two digits long (eg 60) and the last will be two digits long (eg 13) its the last number you need and this will be the lowest of the three numbers
  VaVa
13" 0r 14"..... somebody on here will be able to tell you, but it may depend on what model it is...
Oh, and dont be tight - buy her a set of Alloys!!:D
  Octavia VRS
more likely if its a standard 1.2 clio h reg then it will be 13". My mate has a J reg clio rt and his is 13"
Sounds like 13" is most likely, so I will go for that unless she visits beforehand and I can look at the tyres.
Thanks lagerlout, you reminded me to check my lucky dips on the lottery site. Unfortunately I havent won, so no alloys!!!
Thank you all for your help.
Chris
