What the hell is this?!
MattRS182
  #3 PH2 172 Flamer
just noticed this please enlighten me?
tar
  Astra SRI CDTI,Hornet FA8
Mine doesn't have one of those pipes?! Noticed that bracket with a hole in and wondered what it was for...
Read the replies, it isnt a cable. Its a vacuum pipe (?) which activates the solenoid on the acoustic valve. Perfectly normal.
Im guessing mine doesn't have an acoustic valve if this pipe isn't there!
search acoustic valve on here, you will be enlightened! it reduces noise in the air intake to comply with swiss regs, complete waste of metal/plastic a lot of people pull them out me included!
MattRS182
  #3 PH2 172 Flamer
Wonder why mine has been relocated then,car has warrenty so may get it sorted
davo172
  TCR'd 172
how come iv never seen it on someone elses bay? :s have you guys?
Probly had an induction kit on before you got it and they put the std airbox back on to sell it ? never seen pipe there before on any other 172 182 :S
MattRS182
  #3 PH2 172 Flamer
The person was on here but ain't been on since he sold it he pxd for mitsy colt
  Clio's
could have been re-routed due to a clutch change or something. and then the mechanic put everything back under the battery but forgot that and could be arsed to take it all back out again. As said, if it works then leave it.
  Ph1
Its probably been re-routed to there as the mechanic didnt want to bend his back or for quickness (BEING SERIOUS)
Its nothing to worry about but im guessing if it really bugged you, you could unplug it and relocate it on to the appropriate clips yourself?
  Lots of Alfas
As above its nothing to worry about and its nothing that needs to be fixed under warranty. You can easily unplug it and re - route it yourself but its not going to cause any damage how it is.
MattRS182
  #3 PH2 172 Flamer
oh ok thanks for the help everyone appreciated, learn something new everyday:)
