whats this, whats does it do and where does it go?
http://www.k-tecracing.com/show_product.asp?id=182
answers on a postcard :)
sounds mighty impresive though.....
"It works by firstly bleeding off a small amount of air at tick-over which improves emissions without affecting smooth running, secondly at medium revs it oscillates, creating pulses of air which cause turbulence in the manifold and thirdly at high revs it creates a vortex or swirl in the inlet gasses."
  Ziel Nurburgring
I'd spend your money on those instant 20bhp chips you can buy on ebay, thats where the real performace gains are to be had
  MERCEDES CLS AMG
Renault Clio 1.4 energy Performance Mods
Hill Power Modified Chip.
MC01
All of our Renault modified chips are developed and programmed in house on our Superflow engine dynomometer and have been mapped for optimum performance and engine safety by revising both the fuelling and ignition maps, giving power gains of approx 10/12 bhp All subsequent chip upgrades included in higher spec engine modifications, (provided the upgrade work is undertaken by us) are £35-00. Chip price includes fitting and rev limiter increase where appropriate.
Cold Air Under Bumper Scoop.
UBS01
Air induction scoop which fits under the dirt shield on the near side of the car, allowing cold air to be feed straight to the induction kit.
Standard Air Box Performance Filter.
STF14CL
Direct replacement RAMAIR foam filter to fit the original air box.
Catalytic Converter By-pass Pipe.
CBP14CL
Direct replacement straight through pipes allow exhaust gases to vacate the engine far quicker allowing better filing of the combustion chamber aiding engine pick up and power. (Vehicles registered after 01/08/92 require a cat for emission regulations). Supplied with mounting bolts.
Hill Power Modified Cylinder Head fitted.
MH14CL
Cylinder heads are fully rebuilt using new genuine parts as necessary, ports are reshaped and valve seat angles are modified to aid better flow into and out of the head, we also port the inlet and exhaust manifolds, (why port the head if the manifolds restrict gas flowing or out). Fast road camshafts are fitted with aluminium vernier pullies for accurate modified camshaft timing and one of our own modified chips mapped to suit this specific conversion, giving a power increase of approx 15-20 bhp. Heads are also skimmed for increased compression ratio and most important flatness. Included in the kit are all necessary gaskets, seals, and a new camshaft belt. All modified cylinder heads are exchange and price includes fitting.
Hill Power Cam conversion fitted.
CC14CL
This conversion whilst not having the same top end power, as a complete modified head will give noticeable power gains through modified fast road cams, vernier pullies and a Hill Power chip to suit. Conversion Kit includes new camshaft belt, appropriate gaskets and fitting and vernier set up
Caps and covers.
Ignition coil cover - ACC01
Hill Power silicone hose set.
SH16V19
Silicone hose sets comprise all water hoses except the bottom hose and are available in various colours. Blue is our standard colour. Other colours available, Red and Yellow. These non standard sets cost an additional 15% with a delivery of min 28 days payment on order.
http://www.hillpower.co.uk/
