Wheel bolts torque??
is this the correct torque setting for a mark 2 172? and also would this be the same torque setting for the locking wheel nut? i've had in the past the locking wheel nut not tightening up to the same torque setting as the rest of the wheel bolts.
  PH-QUICK
coolio, cheers guys.
just to throw a spanner in the works just found out that my locking wheel nuts have been waiting for my return home (thanks coolchriss555k), opened them up to find out the leaflet in there it mentions to torque the bolts to 130Nm....hmmmm what to do, 130Nm or 100Nm??
  Clio Sport 182
i didn't want to start a new thread so i will ask here.
The wheel bolt torque is 100nm but what is the torque figure when you come out from a track session and you checking your wheel bolts when your hub / wheel bolts are really hot?
Mr Trailer Man
I use 105nm day to day.
You don't want to be tightening them all the time when hot as you'll stretch the bolts.
After the first session, let it cool a bit and then check again to 105nm. Then again after lunch, they shouldn't loosen tbh mine never do.
  Clio Sport 182
Ok thanks for the advice.
