when braking a light flickers on the dash
You've got a short to earth. Check the cables going into the rear clusters. I had the same. I took the plug out of the socket. Took the rear light clusters out and bent the prongs of the socket so they were closer together. Put the plug back in and because the contact was now better, the problem went away.
Same here, the last pin moved a tiny bit and that was causing trouble....
Also check the earth cable itself which runs from the rear cluster downwards, it attaches to the body work in the boot and you'll find sometimes its a little loose.
I also have this problem, also does it when i put car into reverse, very annoying!
mines the same! had condensation in my old boot 'spoiler' so changed it to a dynamique one. still got the problem. tried everything, including the given points above. really pissin me off. the weathers s**t as well so cant get to it. embarrassin as f**k
changed both circuit boards today, sanded between the pins and sprayed them with some WD40. all sorted :approve:
