where.for.a.182 remap
What modifications do you have? if its just an exhaust with decatand panel filter? maybe a generic rstuner map would suit it more.
As you can't get much bhp increase through mapping on minor modifications
hey guys just come across this and not long got my 182... if remap a 182 that just has exhaust and the rest standard do you get any bhp or is it waste of time?
Yep. Rs192 full exhaust. Magnecor red leads. Bmc panel filter. Whats an rs tuner map and what can i expect. Whay would be the next mod. I have dodgy cylinder 3 injector. Would injector upgrade hold any gain
injector upgrade won't give any gain tbh.
The rstuner is a module which you connect to your car via the obd port and a laptop you then load a new generic calibration(map) it raises the idle to 1000rpm so helps with the lumpy cold starts.
It smoothes the power delivery out and gives more torque low down,the" 5k kick" is faded out slightly and utilising the power throughout the whole rev range
And the limiter is raised from 7200 rpm to 7600rpm iirc
Do a search there's loads of info on the rstuner
