Which is injector number 4?
  Clio 182 FF
Hi guys injector has failed and wanted to check which is number 4 before I change them? I'll do the usual swapping to check but no idea which end to start with!
MarcB
  182 Trophy & 197 F1
So rather than the car being in the order of
Belt / 1 / 2 / 3 / 4 / Airbox
They go the following way of
Belt / 4 / 3 / 3 / 1 / Airbox
  Clio 172 phase 1
Yes the 2nd option it's the one tucked up by the alternator :) Absoloute runt to get in and out IMO changed no 3 ... Won't do it agen lol easy yes nightmare yes
  182/RS2/ Turbo/Mk1
Yes that is correct.
Catches everyone out when they first work on these if they are used to proper cars, lol.
  Clio 182 FF
Got it changed at the weekend, was a little fiddly and required a bit of grease on all the rubber seals to get things back together but was very simple. As said hardest part is getting the seals apart and back together again.
BTW Renparts where significantly cheaper than everywhere else I called for the injector.;)
