Which Lambda Sensor?
Car  Mini turbo, Clio 182
Hi,
I am trying to clear the EML on my 04 182 Cup, using a bluetooth code reader it is showing the fault as O2 sensor fault (I forget which code, until I can check again at the weekend and confirm).
I have a few questions:
1, Does anybody know the fault codes for pre-cat and post-cat? So I can determine which one to change, I am unsure if mpg has been affected as its purely a weekend toy.
2, Are both pre-cat and post-cat sensors identical, if so I can order a sensor today, regardless of which is faulty for fitting at the weekend.
3, What are these Lambdas like to remove? Do you get any problems with the exhaust heat "welding" them in? Any tips for removal?
4, Finally, anybody have a good source for these sensors, or is it just a local motor factor jobby?
Thanks in advance, Matt.
