Hi, i'm looking to buy a clio sport shortly but not sure which model to get. Either a 172 cup or 182/ maybe 182 cup. Just want peoples opinions. Also common faults to look for.
:slap:
Helps if you tell us what you're looking for!
The 172 Cup is rawrest, the 182
actual Cup is a bit so-so, the 182FF with both cup packs is good but heavier than a 172 Cup and still has aircon.
Do you want aircon? If you don't want aircon get the 172 Cup.
Things to look for:
Make sure the cam belt, aux belt, tensioners and dephaser have all been done recently by one of our known specialists (not just someone who promises they know what they're doing/the seller says is a specialist), this is ~£500 if it hasn't been done and it's not worth risking it.
Rear dampers wear quickly, if they're gone it'll fidget like crazy under acceleration. Not overly expensive to replace.
Exhaust mounts are made of cheese but again cheap and easy to fix.
Standard exhausts can rust pretty quick too, most will have a stainless catback by now.
Engine mounts can go, particularly the "dogbone" gearbox mount, you may notice vibration (even visible gear stick wobble) and/or a stiff shift.
Listen for gearbox whine, synchros can go. Expensive fix.
Hazard light button breaks very easily, get the seller to press it for you.
High level brake lights go.
Fuel pressure regulator can get lazy meaning you might need to wait a second for pressure to build before starting.
CD players are temperamental, sometimes they wont play, sometimes they won't give your CD back.
I'd be inclined to walk away at any weird electrical faults as the UCH (electric gizmo) can die and that's an expensive one too.
If looking for a Cup you need to be sure you get a Cup, not ripped off.
I think that covers everything. Sounds a lot but that's just because they're in the price range where a lot are not getting looked after and there's a lot of understanding of the car because of the strong community.
/essay (*-_-)
