I have one
Whats it like to run any issues ?
Have you got any spares?
Is yours a valver,pink and was at New Brighton this year ?
No different to run from any other clio really, they only things that need more attention are regular oil changes on the gearbox and keeping the rose joints on the hubs clean and lubricated or they wear out faster and at £90 a pair for the proper ones you want to get the most out of them you can.
I do have some spares which i have manged to acquire over the last couple of years as my car did not come with much of a spares package. The parts you will find hard to get hold of are things like hubs, driveshafts, subframes etc. Most of the other parts are just standard clio stuff.
If your thinking of getting one for rallying i would just stick with the pink car and get a sequential for it, there will be no benifit and just more expense converting a mk2 cup racer.
Yes it was...Got a class result in the end but clutch cable issues hampered us in the afternoon...!
Ah brill I did it many years ago and a good few sprints.
You were on motors the other night, car looked very good !
When are you out next ?
Looking at the Mk1 and Mk2 subframes and the cup engine mounts it looks as if the mounts are a direct fit on the MK1 subframe and the Mk2 cup subframe was modded to suit.!
The UK cup racer box was used on the Mk1 Group A clio so maybe thats why (Europe cup cars used the generic Sadev St75 box).
http://www.youtube.com/watch?v=oNyRPNHs2iM
http://www.youtube.com/watch?v=v5I4Ei2ojfo&feature=related
Some footage from the event...!
Looks pretty rapid even with the H pattern in them video's what it like to hold onto with that sort of power?
Cars is great and up there fighting for class at every event now, box is the last piece of the jigsaw..!
JC5 box with Gripper diff and 5.2 Final drive for sale section soon....might be of interest..?
This was the box we have used for the last few years and been great, just rebuilt. 115mph at 7k in top.
230bhp, no power steering and 8 inch Michelin slicks, its a good work out on tight twisty stuff.!!!! may pinch the Cup racer Power steering pump and get PS sorted.!!!
Haha brave man, i find my arms tiring even with PAS. Mind you the diffs in the Sadev are bloody tight 85% lock up iirc. How much are the Michelins and where do you get them from? been wanting to give them a try, currently use dunlops which i find are good but have heard michelins are far better.
We ran with these in the Hungarian Clio Cup.n H pattern sadev dog box would be just as quick as a sequnential in reality. If you watch the old WRC rallying, amongst the group A clios in the lower classes, quite often the fastest clio was an H pattern one ahead of sequantial cars.
There is an interview someone on youtube where ragnotti says he is quicker with the H pattern. Its in french though, so you need to find the translated version.
Plus we arnt talking about 1/4 miling anfd so milliseconds doesnt make any real difference. In a club level mk1 rally car an H pattern will be just as quick, but less than half the cost.
But then the 5 speed is 5 kgs less in weight. Might save the second over the stage you lost from the millisecond gear changes. And the 2.5 to 3 k you save in money, you could chuck at the car in other places and easily gain back the second and more.
My personal opinion is that if the pink rally car has manual steering like we are told, then the driver will be losing lots of time with that. Add back PAS and i bet the car goes faster. I have read so many comparisons between manual and PAS and the PAS is always quicker. Cheaper than buying a 7k box.
Ignor this clown its spongeRob squarepants and is banned....
Sequential quicker than a h pattern dogbox as i have driven both in a clio. 1-2 seconds a stage x 12 stages is the difference in winning and losing the class win.
So youtube is your assement criteria LOL as said spoken like a person who has never competed. Go and do a couple of years competitive motorsport and people may even listen to you.....
Again, logic does not seem to be your strong point. Just as Adrian Newey doesnt need to be a World Cahmpion racing driver to design a quick racing car, i dont need 'a couple of years competitive motorsport' (re: some very basic low level club motorsport) experience to know how a gearbox works. All i need is some logic and a basic grasp of GCSE science.
A dog gear is a dog gear. A cog is a cog. The cogs and dog gears in sadev and hewland sequential and H pattern boxes are the same. There is no mechanical difference. No magic pixies live in the box and sprinkle special dust on the sequential components. They are the same and the speed of change comes from the fact that the gears engage under full engine load (with a cut out) with no need for the clutch. As both boxes contain the same structural components and are under the influence of the same mechanical forces, the only variable is the change mechanism (ie the lever and its connection to the gears).
Therefore the speed of change is related to the movement of the lever. Now i know this might be hard for you, but just try to understand that it is irrelevant if you are moving a sequential lever backwards once, or a non-sequential lever the same distance forward once. Once the lever has reached its final position the gear is changed and the action complete.
Considering that the SDTSA box has both a sequential and an H pattern variant with 6 gears, i can see no reason why the sequential version should be any quicker than the H pattern. In fact if you go over to trident motorsportforum, Gareth has been running the H pattern STDSA for years in his championship winning sprint car. With 6 gears. Check it out (williams 0089), you might learn something.
So please explain why there would be a difference in change speed?
I remember you had a similar inability to grasp the concept that changing the final drive on a JC5 box is not the same as changing the ratio of the individual gears. So i am not holding out too much hope that you will understand my explanation. I will draw some pictures next time and colour them in for you.
