Clio 172
Okay my 172 destroyed a set of pilot sports in less than 1500 miles so I decided to refresh the front of the car before getting the tracking done. The koni dampers were nearly new, fitted by myself a few months earlier, but I thought I'd do arb bushes, track rod ends, lower ball joints and wishbone bushes. Even after checking the forum and reading the horror stories of polybushing I thought I'd give it a go. This was about 6 weeks ago.
Removing the wishbones was fairly easy. That's when the fun started. Removing the existing bushes was tough going, although an upgraded blow torch helped a lot. Fitting the new bushes was very tough, just needed to get brutal in the end. But now I'm stuck.
I'm fitting powerflex black bushes. My car is already totally inappropriate for my daily 100 mile commute so might as well make it even worse (it'll probably end up on track like the 205 that preceded it). The problem I have is the washers that go on the end of the bush are held in place by grease, nothing more. When you try and fit the wishbone in the very tight bracket the washers don't fit. One washer does, but no way two are going in. How do I fit the wishbone? Is it possible to glue the washer to the bush? I thought I'd overcome all the obstacles, but this one is the tipping point.
Note to anyone finding this thread in the future. DO NOT POLYBUSHING YOUR WISHBONES. ITS A NIGHTMARE JOB. It has cost me a fortune in tools and I've even had to buy another car to deal with the Clio being off the road. It's a 306 gti, it's awesome.
