Why my BHP gone...??
  Shhh
I cant figure it out... Its a 182, not a Clio 140... ;)
when renault measure it its at the fly, but that was their protoype engine, so everything is as it should be, no crappy inlet manifold mouldings, or badly cast ports in the head, everything was perfect for their 1st 182 engine. BenR should be able to get your 182 to where it should be if your not happy with it.
  Shhh
AJRMOTORSPORT said:
Claps hands. you have the most powerful 182 eva.. lol... not a bad result.
Haarr Haarr..
Now, should it be that low..? How come others have 179bhp results and my ickle clio has 140bhp.?
Think K&N stiffed me and i need it to be run again..
  20VT Clio & 9-5 HOT
because 179 will be at the fly and that graph is at the wheels probably which is about right!
torque is miles out tho!
"A good guide is to deduct 10% of the flywheel figure plus another 10 bhp for FWD"
Just got this^ from another post. If it was true 180*0.1 = 18 (10%) + 10 bhp = 28bhp loss so should be around 150bhp?
130bhp would be a about 30% transmission loss?
Going the other way a 9bhp increase at the wheels would be what at the fly 11 bhp? A completely standard 182 with an air filter makes 191bhp??
Have I done all that right? If I have it seems wrong. (if that makes any sense!)
  Shhh
When K&N market it as Clio 182 8bhp gain, just think of my car.
Oh yea, i filled it up with 95ron fuel on that day, not the 98ron as spec..
  182 Full Fat
Fifth gear proved that Optimax is the stuff to have over the BP ultimate. I've just put some Tesco 99 in, think it may need a few tanks before I really notice anything though!
  Turbo'd MX-5 MK4
i've filled mine up with Tesco 99, good buy at 95.9, but I've yet to really drive the car with it
  Megane R26
Gotta love the 99ron, only 90.9 round my way, and as the ole lady shops there, 5p discount off every litre. so filling tre car up is cheaper than filling with standard unleaded :p Although heard that to make up the octane levels in the tesco'99ron they used some biochemicals or some sh*te. :/
  20VT Clio & 9-5 HOT
japan and other countries have over 103ron, so its not a major big deal its just petrol companies being tight b******s!
  Shhh
Andyman said:
Well if the torque figure is wrong how can anyone believe that the BHP figure will be right ??
Exactly as what i was thinking before, surely there must be something wrong as the clio only put out about 200NM of Torque on detailed on the site. Ive took some pictures of the fitment, im not really happy with the way the thing is fitted. Would of thought they would of done something more with that extra air hose that is nolonger required. The standard airbox has 2 inputs, one from behind the headlamp, one from the bumper.
Some pictures of the fitment... notice the damage to the filter already after 200miles of use last night on the motorway. The damage is caused by the engine bracket. Spoke to the R&D department, and they said that the filter was marked in that position originally.
Cold air feed disconnected
Suspected Damage
Can anyone confirm if the bolt circled was ment to be there..? Or has that been put into the original air intake.?
i'm actually surprised people are reading into a bhp figure like that when you looks next to it and see the torque figure
somethings amiss, and i'd get it checked out on an independant engine dyno, just to make sure
it would explain some of k&n's claims though
  Shhh
Can you confirm that bolt for me, im just on emailing them in R&D, works out the car gained 233NM's from the filter for which i suspect is very incorrect.
Need to put the think about the bolt into the email....
As it says on the chart - "uncorrected". Presume they didn't measure torque so the max figure at the bottom is spurious. AFAIK you can only get a corrected at-the-fly figure if torque is measured as well. Apologies if this is b****cks...
/G
Have you tried a different Dyno - they all give different results - my Impreza varies by upto 20BHP, even when corrected, using the same dyno type but at differing facilities. The one you are using must be suspect as your torque figure is more than your average STI Impreza has. Since I also drive my partners 172 I can assure you that theres no way it has that much torque.
  Mondeo STTDCI
Why didnt they just cut short the other useless hose and point it toward the other one?
  Shhh
Good point... tho i asked them not to modify the car i wanted to put it back to normal. Now they have drilled the original pipe, i cant put it back together...
Ive let them know...that pipe wont be cheap.. :)
Ali
  V6, Trackhawk, GTS
Thats a bit of an old wives tale matey, doesn't always follow that specified value for transmission loss.
