Will my car fail and MOT
  Mk4 .:R32
With 3/4 plate, no side lights and no rear numberplate light?
Easy to sort obviously, just need to know before I take it in. Also, if they did say it had failed on having a 3/4 plate for example, could I just take the standard plate with me on collection and swap them over there and then?
Cro
  Meg'd r27
the rear light and side lights i would imagine are a defo and yeah a friendly mot tester wouldnt have a problem with you swapping the number plate over, as long as the spacing looks ok id say it should pass
  Mk4 .:R32
just stick the plate over it with tape or somet
I thought that, cos at the mo its stuck on with neoprene with strong adhesive on both sides, if I start swapping the plates it will loose its stickiness!
Also, the passenger headlight is levelled quite high (tried changing it but it's f**ked), would they fail it for that as well?
  Clio 1.2 16v
maybe if you take all 4 wheels off to be sure then put it in for mot they might not notice the missing numberplate or light
  Mk4 .:R32
well if you stand infront on the car you can't notice it, but if you bend down to the level you would be in a car, it feckin blinds you
  Mk4 .:R32
well the place I was going to get it done is across the road from work, a family run garage, which I'm pretty sure have interbred a few times, so they probably won't know how to change the headlight level.
They pretty much told me to f**k off when I asked them to look at the speedo light as it wasn't working. I only use them for convenience
