Will these wheels fit my Clio
  Clio Campus
Hi guys , new here . I have a clio campus and had recently put the sport front end on it , bumper and wings . For obvious reasons I’m urgently looking at getting some new wheels . I have found some wheels that I quite like but they are 15” but 8” wide. The offset is et25 . Tyres size on the wheels are 195/50/15 . My question is , will these fit on my Clio ? Thanks
They’re some wide wheels, standards are either 6.5 or 7 so 8 is massive. I’d be also checking the centre bore (60.1) and a the BCD (100).
Standard offset is ET45.
I’d guess that these would catch on the struts at all sorts, but I could be wrong.
Steve1986
CSF Harvester
  Clio 182
If anything you'd have more clearance around the inside of the wheel. You're making the wheel 25mm wider but you're moving the centre outwards by 20mm, so you'd be gaining 7mm or so.
They might poke out from the arches a bit though, standard offset wheels with 20mm spacers are basically flush, so an extra 12mm would probably look daft.
I always get the offset the wrong way around 🤣
Also not they stick out beyond the arches that’s an MOT fail.
  Clio Campus
I did also forget to say that it has 60mm lowering springs on it too also has adjustable camber on the front too
Brigsy
  T.Turbo
They will catch/hang out arches on the back. When compared to mine on williams clio 7j et36 wheels, as will poke out 23mm more
Steve1986
CSF Harvester
  Clio 182
What if I had 7” wide wheels instead of 8” but same offset ?
Your tyres would fit better, there'd be plenty of space on the inside edge, and the fitment on the outside would be pretty nice. I've got 7" wide wheels with 10mm spacers and 37mm offset, yours would only be 2mm further out.
What wheels are they? ET25 is a fairly aggressive offset so I assume they've got a bit of dish to them.
