Willy Clocks in a Mk1 1.2, help?
I want to install some Willy clocks into my 1.2 so I have a Tacho. But my question is, will I be able to connect the other clocks ie temp, oil guage etc? As removing my clock pannel will also remove the warning lights for the oil temp etc :S , which as you know are spread out over two units in the Williams.
I will also be buying the top part of the dash (dont know the name of it) to house the extra clocks if I can use them.
Gaz
