The windscreen washer pump does not spray but still works as you can hear it working, iv also removed all the tubes to check doe blockages but all good. Water does not come out of any of the ports on the pump.
On closer inspection water can be seen filling up inside the sensor plug!
Its almost like the pump is filling up with water and is coming out of the electric sensor socket and not the actual tube.
Any ideas? Surly this can be fixed?!
