wireing Boot Release
i have wired every thing up for a push button boot realese all works but i wana change it so it dont work when the engine is on how do i go about doing this thankss
  Polo + Micra
now this is going to be a difficult one
you need to get a feed from the alt but on the signal side (the same signal for the batt light on the dash)
  Audi TT 3.2 V6
Hi rob, what have you bought to enable you to do a push button release and were from?
ta, russ
ta, russ
hey mate
every thing i am using to do this boot realse was nicked off a old escort. as it had a nice push button with a picture of a boot on it
i got it from a scrap yard in ipswich . ( it fell in to my pocket only noticed when i got home :) )
  Audi TT 3.2 V6
might look into doing this myself sometime, doesnt sound like a bad idea and something ive always thought the clio is lacking.
On my mk1 clio wasnt hard to wire in. only thing i found hard was feeding the wire in to the boot. but got there in the end :) wires follow the Rear window washer pipe
  Hondata'd EP3 Type R
on a phase 2 clio, simply use the stock central locking solenoid, wired to a push to make switch on your dash. I got a live from my ciggie lights and my earth goes into my earth block for my install.
Some kits use relays etc etc, I just used wire and a switch, ona phase 2, it shouldnt cost you more than £5 for a switch and some wire. Admitidly I had some stainless steel push to make switches made which were about £10, but to make a push button boot release tha tworks when the ignition is on is very easy.
However does anyone know how ican make it work when the ignition is off?
