Wireless Help
Right, my boss doesnt know im using his connection on the wireless, so I can go moving the actual router etc.
Its been working for a year or so, then he goes and has a change around in his office and it no longer works.
It connects to the network but nothing will load.
The packet thing sends and recieves but very very slowly :(
Any suggestions?
Could be wrong here, but whats the signal strength like? Seen something similar a few times where the signal is low, it will connect etc but its too weak to actually load anything
Hmm in the case I have no idea then lol - he wouldnt have changed the security or anything like that?
Strange for it to happen if you have a good signal. Try moving your laptop closer to his office as a test to see if thats the problem. Could just be a coincidence.
Windows generally cant handle a weak signal and I suspect this is the problem. As said above the only way to really tell is to move the laptop closer to see if it works there.
i know you probably already have but try re-strarting the router, or just leave it unplugged for a few minutes maybe?
