Wordpress changing domains?
  Fiat Panda 100hp
I have a blog, but I am going to be changing domains and hosts soon. Is there a way I can keep all my blog posts etc as I have built up quite a few and would like to keep them if I can.
Thanks.
  14' Leon Cupra 280
I'm sure you might just be able to download everything in your directories, then sortof duplicate it when you get your new hosting/server. You might have to go through a few things and double check all the links/directories, but i'm sure the new or old hosting company might be able to help if you ask them too.
  20VT Clio & 9-5 HOT
ull need to export the sql using phpmyadmin and import it into your new database with your new host. that and also download and upload all the files on your webspace. you will need to modify the config file too with details of your new database!
