XBOX Live (Not360)
  RS Meg 175
Does anyone still use the old xbox online?
if so what do i need to make it work? i have a few games and the usual.
do i need ethernets or what?
Cheers guys
matt
  Golf GTD
dont think there is a way to take the old xbox online wirelessly, it has to be done with ethernet cable into a router/switch. you will also need xbox live time, and i am told, but not 100% certain, that the xbox live 360 codes are the same as the xbox live original codes.
  RS Meg 175
ok awesome, so do i just need an ethernet into my router then? and a subscription? do i not need an expansion or anything?
KDF
  Audi TT Stronic
Xbox live is the same as Xbox 360 live, I just dont think you can play one another :(
  BMW F31
^^^ er what!?
xbox live is identical to 360 live
you can play each other on all live games!
there's not a lot of people on the old games now though.
halo 2 etc is still used alot but not much else :(
  Golf GTD
i dont know what you mean as in expansion? the original xbox should have an ethernet port on the back of it, run the cable from that to your router/switch.
im sure the manual will have easier steps, im doing this off the top of my head havong never owned a xbox personally, i just have the superior 360 :rasp: :clown:
  Renault Leguna 2.0 T LTD
Add me Draftrabbit when you get it sorted im a ambassador so i should be able to sort you out
