Xenon bulbs.
Car  MK3, 1.2. 16V
Just bought a full set of xenon bulbs for my 2001 Clio H1 55w main beam, H7 55w dipped beam and ice white sidelight bulbs. My simple question is, how do I fit them ? Is it just like any other car, black rubber bit that pops off the rear of the headlight, unscrew the bulb, put the new one in and put it back together again ? Or because they are xenons is there some different way of doing it ?
In that case pop the black cover off the dip beam side and pull the connector off and there's a wire clip that holds the lamp in position, you need to push towards the lamp and to one side (can't remember which) and it'll un clip, carefully take the lamp out and insert new one being careful not to touch the glass.
I've never changed the main beam ones but I'd imagine its pretty similar.
Best to do it in daylight if possible.
