Hi guys, removed my bulb from the xenon headlight and now i can get it fixed back in. The bulb is held in by a black ring and i cant seem to get it to catch right.
The starters are fiddley, inside you'll see a plastic ring that rotates slightly, along the ring there will be notches in it, and you can see where the notches on the plastic ring, have to line up with the notches that let the bulb into the starter.
The number of times I've pissed around trying to get the starters back on, and then realised the plastic ring was out of position, is rediculous.
