xenon light fault
Car  Clio 172 cup
hi guys. right iv been having this problem for a couple of weeks now but still no joy. one of my low beam xenons isent working the other side plus every other light works except this one. iv tried changing bulbs, black box attached to bulb and power module on bottom of the light still no joy i have checked fuses and all oky. what else can i check?
If you've got a multimeter, then test for voltage, continuity and resistance in the wiring. If you haven't then swap all of the components from the working side over to the non working side*. If it then works, swap over one component at a time until it stops working. This is then your faulty component.
*I take no responsibility if this causes any other faults.
