Xenon problem
Hello,
Previous week, I had one Xenon lamp that was out of use. Next day it worked fine. Today it was flashing several times and was out of use again. Is this a common problem?
I saw also that the rubber cap felt of and there was condence in the headlight unit. Hope it has nothing to do with that
Could be the bulb or charge pack
Under warrenty at all ??
Could get costly, make sure the cap is put back on properly that will stop it getting wet and building up condensation.
yeah as Has says check it's sealed as those rubber things cost about £5 from renault whereas a Xenon lamp is £130 ish!
If it's flashing I would guess at the starter or the lamp has gone.
take off the connections, and dry them out, could be the slightest condensation on the contacts
