172 cup screen washer pump
  172 cup
hi guys, done a search but couldn't find the answer i was looking for.
does the cup only have one pump for front and rear or is it two seperate pumps?
my rear washer still works but the front has packed up, seeing as i don't use the rear washer i was just going to swap them over but can only see one pump after having a quick look?
  02 Iceberg 172
Same pump for front/rear washers - if the rear is working then the motor is fine but the small rubber valve that sends the water front/back has swollen. There is an easy fix for it and a thread on it here - just need to trim the rubber a bit and all will work ok again.
