Hi fellas,
I'm shortly going to be booking my 05 182 in for a 60k service and was wandering what people recommend having done to keep the car tip top. The cam belt, dephaser and water pump were done 9k ago. On my list are;
Engine oil change
Coolant- Renault type D presumably but how much does the system take?
Brake fluid change
Air and pollen filter
Power steering fluid (from looking through past receipts from the previous owner I can't find a record of it being changed)
Spark plugs (were last changed at 37k. Still needed?)
Gearbox oil (again last changed at 37k so is this still needed?)
Anything else worth doing at the same time? The car gets driven very gently to work each day with the occasional blat if that helps.
Engine oil change
Brake fluid change
