Bead blasting plenum and fuel rail guard
  200,182 Trophy, Cup
A bit linked to the previous post on powder coating but I'm wanting a nice untreated finish and wondered if anyone had gone for a simple bead blasting and whether it presents and problems to the mating surfaces etc. Also in removing and replacing are any new gaskets or seals needed
m&l172ph1
  197 Cup
Bead blasting won't damage anything. Mask off the faces and block off any holes to restrict as much media going into the manifold as possible beforehand. I plan to blast some spare ones I have at work.
Gus
  182Turbo,DCi90
Ideally you want vapor blasting using ceramic media. This will give the best finish.
  200,182 Trophy, Cup
Impressive, just had a quick google search and found a place only a couple of miles from me
