R26
Just trying to sort out a misfire problem which only occurs when the car is cold. Rstuner comes up with "O2 Heater fault" which had me completely confused because it sounds like it was to do with the heating matrix.
Ive just thought: does the clio use heated lambda sensors? This would explain the fault code and the fact the misfire is only when the car is cold. Would a faulty heating element be enough to make the car misfire (sometimes down to 2 cylinders) or is it more likely to just affect emissions.
