Mk3 won't select gear (engine running)
JP83
South Central-Oxfordshire
Morning all.
Went to go to work this morning, and the car won't select gears with the engine running.
It will; however, with the engine off.
It also appears to drag slightly when the engine is on, and I'm in 1st (already selected with the engine off).
Any thoughts?
@Dan@SJM
JP83
Garage just rang - said it was playing up still when they picked it up, but weirdly now, it's working.
Took it out for a short drive, and no problems.
Asked them to take it for an extended drive, see if it's still ok.
Something blocked/ got stuck?
@Dan@SJM
Garage also said if they need to look at the gearbox, it's a 10 hour job!
JP83
Well, apparently after the extended drive, all is ok, so still no idea what it is.
I've been told that to replace the clutch though, it's a 10 hour job on these cars!?
JP83
Cheers @Gorms
I'm off next week so will keep an eye on it. Not really what I wanted before Christmas though, especially having forked out £700+ on house stuff for next week.
  Clio mk3
Mine wouldn't select hear back last year,or it would but would be hard to select gear. Turned out it needed a gearbox oil change an was all like new again. Not saying you could be lucky like me but its worth looking at
