Project mk1 FRS
Barron
  Turbo S,Exige,R5,182
  FRS
Your thinking of the o ring that is removable, i have no leaks there, im on about the part where the plastic piece with three holes screws onto the housing, and also when the housing is bolted onto the block i can see the rubber seal around the thermostat poking out the top, i cant remember how it looked when i took it apart such an amateur! Haha
Barron
The thermostat housing is made up of 2 bits with 2 seals.
1 - Housing to block with seal
2 - Front part of housing to main housing (held by 3 bolts) which is sealed by the thermostat
Which part is leaking?
  FRS
I got it sorted i was being an unreal nugget and had the thermostat against the head! Idiot i know, its sorted now no leaks and running sweet!
  FRS
  FRS
Huge relief! There is the tiniest droplet comes out the thermostat housing but i will put a run of sealant along the join at the weekend!
Barron
I would not be messing around with the cooling system of a Focus RS with sealant.
Remove the thermostat housing and fix it properly before it fails completely.
  FRS
how will it fail completely? The thermostat that sealed it was sealed with ptfe tape before this loctite gasket is meant to be a gasket so fully fit for purpose
Sam
North East
  Electric 🔋
Looks lovely mate.
I know a lad with one and it his sounds mint.
  FRS
This thing sounds sweet and pops flames for fun! Couldnt get anything else close for the money it cost!
Planning 17" team dyanmics pro race 1.2s shortly !
