PC Start up problem. Help Please
Scrooge
Car  E55 AMG
Right a friend at work is having PC troubles. We can't get it to start up..
It keeps doing this then restarting
Tried another harddrive and it said no
Help please
Ant
Boot it up, hold f8. Press disable automatic restart on system failure. You should then see a blue screen (if it's crashing). Post the error up
Thanks,
Pushing F8 doesn't work at all it just carries on going, this is the screen and options I get
sfc /scannow (from command prompt) once in safe mode or run system restore. Looks f**ked!
Run safe mode with command prompt and it goes back to this same page
Will download malware bytes now
Didn't think it would. Have any software / drivers / windows updates been done lately?
Also try removing one stick of ram at a time and testing the machine (even though this usually isn't the sort of error caused by RAM issues)
Done that earlier too, nothing. Will do it again to an even earlier point and see what it does.
Go back to first restore point. I would download and burn Kaspersky Rescue Disk 10, run that and see what it picks up - could be a virus as Thomas said :) OS does sound knackered though, pop a Windows 7 disc in there and repair that should fix the bootloader problem.
Restore it from a previous date. I had exactly the same on my laptop a few months back. For some reason one day it just didn't recognise my log in (which I set up when I got it years ago)
ffs lol! Any other machines you can nick some ddr3 ram from?
Okay, did you say you also tried another hard drive?
If you did try it again but with automatic reboot disabled so I can see if it's faulty hardware or software
Nothing here I can nick a stick from :(
The IT guy just came down and took it away as he said he has a few repair disks, hopefully he'll sort it.
Thanks again Thomas and Thrill, much appreciated.
Session Manager kills itself at initialization if one of the files listed under HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\KnownDLLs fails verification, in this case STATUS_IMAGE_CHECKSUM_MISMATCH. There are ways to find which one but a repair is typically the quickest way to fix it.
