Dr HMS Derv Destroyer
								MK1DCi/vivaro/REN’11
				hi all, recently had a dci come in , 2004 delphi 1st gen k9k.
the customer dropped the car off to us with a problem ,
the problem consists of first start after car being sat still over night.
glow plugs have been tested and fine. inc glow plug relay/timer
glow plug light goes out, go to start it and it will start but only revs itself too 700rpm and then dies.
fire up again and its fine and will idle perfect, and drives perfect.
no faults found, fuel filter split and inspected for contamination of a failed pump, to which no metal parts found. in tank strainer checked and not clogged.
brand new fuel lines fitted at renault dealership last month.
new filter fitted, OBD diagnostics on live data shows 290bar on cranking, as soon as the engine starts the pressure drops completely off.
second fire up shows 290/300bar and then holds nicely on idle.
leak off test has been done and found N0'2 injector ( french side gearbox end )
to leak back excessively , all the others return a minimum amount.
am i right in thinking this injector is sticking open, caulsing a big pressure drop, which inturn needs two starts to get it to go?
runs fine all day after that, until the next morning.
can anyone back up my diagnosis ?
the guy is a very picky customer ( and should be after having his pants removed by renault ) , i would just like to put down some hard evidence and back up from other people. a full printed report will be handed to him before ordering parts.
@MicKPM @Dan@SJM
thanks
raz
@MicKPM @Dan@SJM
thanks
raz
