windscreen and feet not blowing air help
ADS_V6
Car  172 cup clio v6 st
doing my head in,no air coming out of front screen and feet face works when on windscreen makes noise but no air help please
thanks then how do i test it the passenger side blower is all loose by glovebox
Graham ive managed to get air in footwells the white cog type thing was stuck but still no windscreen demist?
Sorry bud I didn't see you post in here. I can't remember what the manual controls are like but there is a setting specifically for feet of course so you've probably got that one.
can you pull it more or here anything in the matrix when you try and turn it up to the windscreen. You'll want to try and avoid changing the matrix if possible because you have to take put the whole dash including wiring and frame which takes bloody hours.
if you look under the dash you can see the cogs which change the flaps. Are they moving freely.
i think the demist windscreen cog is problem where is it located?
hi i think its the actual thing that controls the different settings that i need , is that the blower motor or servo ? thanks
