Clio Mk4 only blowing air to footwells
charltjr
I have a problem with the climate control on my Mk4 RS 200.
I think there’s likely a blend door issue because whatever I do with the controls I only get air to the footwells and the tiniest gasp out of the other vents.
When I turn the ignition on I can hear a clicking which sounds like the system trying to move the air direction flaps. No fault codes.
Cant find much online about this, anyone had the problem before? Worst case I’ll just rip the dash apart until I get to the relevant bits 😂
It’s not a temperature issue, purely air direction.
Sash
  A Yellow One
Drivers side flap motor. Take the panel off by your feet and you’ll see. Quite easy to fix.
charltjr
Is the right answer, I got in there today and I can see it’s not sensing it’s end stop and is jumping as it tries to move the arm it’s connected to. Thanks @Sash , I’ll order a replacement.
Sash
  A Yellow One
Peugeot & Citroen share the same motors fyi
