Throttle bodies
  C2 vts/172 ph1
Hi everyone, just bought throttle bodies and was wondering what injectors would be best to run with them also if anyone knows where I could get a smaller rad that would fit with out modifying anything thanks
VW Polo Rad fits, I have one. Does the job for me. But I don't drive on the road and sit in traffic.
Standard injectors will be fine. From memory you only need to get the Megane ones if you're aroun 200bhp.
  RB 182 Cup
I've just finished my itb conversion, get a vw jetta rad as it's slightly longer but still not tall. Also I used megane 225 injectors as they have better spray pattern and if you can afford them cams will make a big difference. I have 421 cams and made 208bhp and just over 173 ftlb torque
SharkyUK
AH Fabrications do a nice rad setup... but depends on how much you are looking to spend and how highly tuned your engine is. I was getting overheating issues on my old setup (ITB's, cams, forged, high-compression) so went with a solution from AH. A fantastic bit of kit but I also appreciate it may be overkill or overpriced depending on your specific needs / budget, etc.
  C2 vts/172 ph1
Yeah that radiator is nice I've seen a few for sale on here they were pretty pricey tho is it the same size as a standard one high wise as I can see it's a good bit thicker
SharkyUK
No mate, it's smaller than standard. The 'old' rad in the picture is the smaller VW Polo radiator that it was replacing. It's not far off double the thickness.
