PH2 clio 1.2 16v
				Ok so the wee clio was only on the road 2 days from having the wishbone replaced and now i have been hit with this problem which i don't have much clue about. Its a 1.2 2004 clio.
So it started a few months back when to test the clio out i give it heaps of rev then changed the gear and i mean it would be near maxxed on revs then change gear and the clio would stall and bring up this warning light (down below) that was my first encounter of this problem. after turning off and on the ignition the clio would run 100% unless i was to rev out each gear so didn't seem much of a problem to me.
I did a bit of offroading yesterday and got the underneath of the car quite muddy but no heavy hits or anything like that so today i did about 10 miles driving then went to start the car up from being at a shop and noticed this light appeared but it was driving fine. so about 10 miles later and the fuel tank near empty i parked up at a friends house for about 30 mins then went to start it up and the car has no throttle response and revs constant at 2000 rpm when i give the throttle a go the rev indicator drops as if taking off from the clutch. The engine management light is now also on after i disconnected the battery and put it back on.
I see a lot of different suggestions on other posts some quite pricey its quite surprising how it just decided to give up like that. Any suggestions would help i'm gonna give the throttle body a clean tomorrow and check the wiring + fuses.
