172 ph1 gearbox leak
Car  Clio 172 RS ph1
hi, spotted a leak from the gearbox, i think its from the selector link ,
and some where near that area.
will add some picture first thing at morning,
any idea where it can leak from ?
It's either leaking from the selector shaft seal (the normal place) or it's the casing join that's leaking.
To fix them properly both require a gearbox strip down.
can get an original from Renault or a split after market one, if oil is coming through then you will need to replace the lip seals as well
