heat shield may of rushed through the nut washer,just put bigger washer on.. see if that stops it.. i did it on mine...My heat shield is rattling at my fuel tank. has anyone removed this? i understand its best to keep the heat shield due to it being the fuel tank.
I would rather replace it for a brand new one.
already done this. the dobber who has played about with my heat shield previously has kindly snapped bent one of the screws so i cant put a nut on it. might heat it and try and get it back into shapeheat shield may of rushed through the nut washer,just put bigger washer on.. see if that stops it.. i did it on mine...
you get some cowboys..mine was just all rotten through..easy fix with bigger washers..someone on here had a rattle.. looked underneath.. the previous owner put a screw through the boot, to try and stop the rattle haalready done this. the dobber who has played about with my heat shield previously has kindly snapped bent one of the screws so i cant put a nut on it. might heat it and try and get it back into shape :blush:
haha thats shocking! my car has as light bit of rust where the heat shield has rubbed from moving. going to paint it with hammer right black and that should help. only a small spot thankfully.you get some cowboys..mine was just all rotten through..easy fix with bigger washers..someone on here had a rattle.. looked underneath.. the previous owner put a screw through the boot, to try and stop the rattle ha
