Hi,
I'm a 172 owner from Hungary, having issues with my throttle body and i saw your posts, here i am asking and advice. What if my revs also fluctuate (between gear change, clutch on and fluctuate from 1000 to 2000) and idles too and high revs at the same time :smile: There is no gasket on it at all and the cable looks worn too, making the pedal hard. But also have a not original bolt drilled in to the cable "rack" oval plastic thing, pulled by a second spring, (made by the former owner to hold in position- also seen on other cars - ghetto mod i guess.). We strip it down, cleaned and understand that tha value in the throttle body is moving from left to right, like half a mm, leaving some space. When it is pushed by hand from the back side of the oval cable plastic rack, revs go to normal. Is it option to screw the bolts on the valve?
I know i had to change the cable and gasket too, but i think that is not the main problem. Looks like it the motion and lost stiffnes of the valve inside the throttle body.
Do you have any suggestion? :smile: What do you think, gasket, and a new cable could fix it or try to get a "new" tb? Found this in France for 200 euros, Original is over 300 as i saw. OEM numbers are ok.
http://www.dpauto.fr/boitier-papillon-7700871215-7700113290-7700113286,fr,4,60XR9.cfm
Now its ok becaulse that second spring handles idle to 1500 rev max, but damn its so frustrating when i kick the clutch, looking like a boyracer acting crazy.
Thanks for any advice,happy easter :smile:
