Newbie with machine polisher
Yeah I've been having a read through, I just think it's time I try a machine polisher out now I cba with hand polishing :smile: plus I reckon the car will benefit loads from it
Definitely, it's night and day.
The Tip with the line on the backing pad to keep it spinning at the same rate is really handy for keeping the same pressure and getting a good finish.
Cheers I'll remember that! Only thing that scares me is messing the paint work! I remember letting my mate loose on my 1st car as he was learning and after that I could see buffer marks in the paint, that's what I'm scared of doing haba
The das pro won't let you do that. Unless you go rotary it's unlikely any other polisher would burn the paint.
Unless of course you feel asleep face down on the machine, probably will then.
Haha well that could happen with the amount of hours I'm working atm feel like a zombie.
I'll do some research on the das pro
Not sure if anyones actually put an order in for the above but at the bottom it says:
"PLEASE NOTE - DISCOUNT CODES WILL NOT WORK ON THIS PRODUCT "
Still not a bad price though
Hes stopped the discount then on the machines ,must not make enough on them.I will ask the owner of saverschoice later
keep in mind if you invest in argos one they recommend a 6" backing plate and new pads for it. unsure on cost of these.
